Mk2 scirocco gt2.
Re: Mk2 scirocco gt2.
If you could get some deep dish g60's on the rear that would be almost perfect.
Loving your pods. Could you stick a 500 word How To together?
Fnar
Fnar
Benobatman
At the moment im just happy to be on the road
2 long years in the making
and im sure i could knock something up explaining what to do
Benobatman
Fitted my sub and amps in the boot, knocked this amp rack up bit then ended up losing alot of boot space so put the amps onto the back of the box.
If you want start playing around what about dismantling the box and either putting a build in the rear boot panel or dumping it in the spare wheel hole.
Got mine in the wheel well (no point running a spare with the borbets so just have tyre weld) and the sound quality is surprisingly good
Benobatman
at the moment i can live with the boot space because when i goto shows all i have is a bag of clothes and a tent so it just goes on the back seat
but the over all sound is quite good at the moment with the rockford powering the focals and the sub facing backwards in the boot
Benobatman
Also need to get some more rear lights... due to the previous owner putting odd lights on.
Benobatman
Finally got a 4 button steering wheel
Also got some matching back light and a new set of front just incase the ones on break/crack
God bless motorhog
God bless motorhog
Benobatman
