Cambelt cover
Cambelt cover
Looking for a bit of knowledge here guys, I'm missing a bolt for the timing belt cover (see circled in picture below) does anyone have a part number or rough idea where I can obtain one? (Not listed by GSF)
Rocco Mafia Car of Choice 2010
1989 Helios Blue Scala 16v *sold*
1994 Mulberry Corrado VR6 *sold*
1991 Tornado Red Scala GTi Engineering RE2000 8V *sold*
1991 VW Polo G40 *sold*
1990 Pearl Green Scala
2020 VW Polo GTi
2020 VW Polo GTi
Re: Cambelt cover
Do you still have the stud attached to the engine as the nut screws on the stud?
Re: Cambelt cover
Nope the stud has gone walkies, managed to find the nut from VW parts but the stud is discontinued, any ideas any one?
2020 VW Polo GTi
2020 VW Polo GTi
Re: Cambelt cover
Partsbase (link above) or etka should tell you the thread size and length of the stud. You can then get one from your local nut and bolt dealer
- unknownmale
Re: Cambelt cover
It's not a straight forward type of stud as there is a nut part to it which holds the engine mount onto the block.
Coupe of pictures.
Coupe of pictures.
Re: Cambelt cover
Looking at the pictures above, it's not a straight forward stud, but includes a nut section. I would think the thickness of this is critical.
Re: Cambelt cover
It's also not some weird vw only fastener. If you know what thread(s) it has, a nut and bolt merchant will be able to sort you outmark1gls wrote:It's not a straight forward type of stud as there is a nut part to it which holds the engine mount onto the block
Re: Cambelt cover
I have had an unusual problem today.. Trying to unscrew the big flange nut which secures the upper timing cover to the block.. trying to change cambelt.
6mm allen head nut backs out ; just turns and is withdrawing the 6mm diam stud into the block, female nut not coming off and cover wont come off. Any ideas chaps before i cut up the timing cover. Ive managed to see inside the cover and have locktited the stud into the block. Hope this seizes it enough so that the female big flange nut comes off as it should tomorrow. Otherwise its carnage.
Re: Cambelt cover
If the stud unscrews from the block you should still be able to remove the cover, have you undone the 2 top nuts and able to lift the cover over the studs or try removing the studs from the top of the head (lock 2 nuts on the studs), remove the alternator belt and then pull on the cover while undoing the big flange nut and stud. Once the cover is off you should be able to get a spanner on the the stud and undo the flange nut.
If you look at my pictures above you can see that nothing should stop the stud coming all the way out.
