wing mirror dismantling
big_wig_074
has anybody dismantled a wing mirror? I have a spare entire mirror unit, but its a different colour, and was wondering if I could swap the back cases over? if not ill have to get it sprayed I suppose, not the end of the world, but the case is the only decent bit on the old mirror and I don't want to break it unnecessarily trying to figure out how to take it apart.
Re: wing mirror dismantling
They aren't designed to be dismantled, unfortunately, so repainting is probably the best idea. Make sure you use plastic primer.
big_wig_074
when I had to switch a mirror from a broken unit on to a new one I literally had to cut it apart to get it out!!!!!
