Dipstick Guide
Lukeh17
Dipstick Guide
Post by Lukeh17 »
The plastic snapped halfway up today so need to order a new one. Do they slide off or not? How do you replace them? Thanks
Re: Dipstick Guide
plastic bit at the top pulls off then slide new one back on till it clicks into place.
Lukeh17
Re: Dipstick Guide
Post by Lukeh17 »
sweet cheers buddy
PeteGLi
Re: Dipstick Guide
Post by PeteGLi »
Warm up the plastic with a hairdryer before you push the new one on - or it will just snap on you.
Re: Dipstick Guide
Mine broke into bits when I removed the old one so be careful not to drop to much down the hole.
marcus
Re: Dipstick Guide
Post by marcus »
Ooh err missus!
1985 GTL 1.8
Lukeh17
Re: Dipstick Guide
Post by Lukeh17 »
haha Thanks for the tips guys
Lukeh17
Re: Dipstick Guide
Post by Lukeh17 »
So the plastic bit has been on awhile now, but it never seemed to fit properly so when I pull the dipstick out, the whole plastic bit comes off too, this is because part of the old one is stuck down the pipe still, it isn't shattered or anything, it just seems where the rest has come off there is a circular part down there.... any ideas on how to remove this?
DT1
Re: Dipstick Guide
Post by DT1 »
A metal coat-hanger. Snip a straight bit off and then bend the end over 1 or 2mm to form a small lip. Using 2 at once will probably be best.
Blueshark
Re: Dipstick Guide
Post by Blueshark »
Tak e a thread cutter of good size and turn it in and pull the remaining bit out .
Joost
Lukeh17
Re: Dipstick Guide
Post by Lukeh17 »
I will try this method, however I am concerned that the plastic is attached to where it's sat in the pipe. Also I am also concerned about dropping it into the sump as this probably wouldn't be a good idea!! Any other suggestions or is the metal coat hanger etc the best method?
Re: Dipstick Guide
Take the metal pipe off first?
jpr1977
Re: Dipstick Guide
Post by jpr1977 »
Put a twisted bit of tissue/kitchen role part way down the dip stick tube/ guide before you start and you can prise the remains of the old guide off with some mole grips then once removed pull out the tissue
Lukeh17
Re: Dipstick Guide
Post by Lukeh17 »
james butler wrote:Take the metal pipe off first?
How do you remove this?
Re: Dipstick Guide
it either screws in or just pulls out.
my mates audi tt one just pulled out but there is a small 10mm bolt holding onto the block on the tt.
im sure i yanked mine out by accident years ago.
the only other way to do it would be to remove the sump then push the broken plastic out through the bottem of the dipstick pipe so you can get all the pieces.
