Glovebox light
christhemann
Glovebox light
Post by christhemann »
Managed to get one of these to fit in my Scala!
Apparently they were only fitted to Storm and GTX Models, has anyone got a photo of where in the glovebox it should be placed?
I suppose I need to cut a hole to fit it.
Cheers.
Chris
1989 Helios Blue Scala
Re: Glovebox light
my old scala had one :) is there not a hole there already with a blanking plug in?
Re: Glovebox light
christhemann wrote:Managed to get one of these to fit in my Scala!
Cheers.
Chris
I have taken a picture for you, PM me your email address and I'll send it, don't know how to use photo bucket!
bluestreak56
Re: Glovebox light
Post by bluestreak56 »
Cheers.
Chris
Hey Ian, would you mind emailing it to me please too mate, I'll stick it up here for everyone else to see as well cheers :chill:
bluestreak56
Re: Glovebox light
b5byt
Re: Glovebox light
Post by b5byt »
wow..I didnt know I had a light there... :chill:
1984 Scirocco Storm Cosmos Blue < Body has really had it, if you need parts off it let me know < Going.
1986 Scirocco Scala (Rocco-Jocco's old one) Having some life put back in to it
2001 Carbon Black E39 M5
2008 Carbon Black E60 M5
Re: Glovebox light
i've actually come across one of these in the shed this afternoon
christhemann
Re: Glovebox light
So, i've got myself one now and had a go at locating the wiring tonight...
Not easy back there behind the glovebox. :dash:
According to the wiring diagram, the wire to use is black/yellow from the fan/blower switch (and a brown earth, which should be easy enough to add).
Found the black/yellow wire but it's bloody stuck somewhere and I can't pull it out.
Any ideas where it goes? If it's easier to get to the wiring behind the fan controls, would removing the centre vents help? Or does that just
give access to the blower motor?
Starting to think a glovebox light is pretty pointless...
Re: Glovebox light
Take the glovebox out, it isn't that difficult and it will give you acres of space to play around in.
It is just a few screws, but take off the underdash shelves as well in the passenger footwell, just makes life a tad easier.
christhemann
Re: Glovebox light
Finally got round to doing this!
Hardest bit was probably hacking the hole in the glovebox, they're pretty tough.
The wiring was already in place, as the wire to use is Black/Yellow and comes from the plug on the back of the fan/blower switch, also paired with the
red wire (giving power to the blower switch) This is according to the wiring diagrams.
I tried tracing the end of this wire as it went all the way to the other side of the car (towards driver side).
Got as far as I could, and then cut it, anyones guess as to where the hell is goes ?! Maybe its terminated somewhere stupid.
Crimped a terminal on it, wired it to the light and then put a wire from (-) to ground plugs
on the right of the fuse box (there was a spare spade connector).
So it works well! But then the bulb seems to have blown. ARR.
Can't find a bulb for it anywhere, its a non standard Festoon 3 Watt type (not the same as the one in the boot thats 5w, or the interior light as its 10w!)
Oh well, all good. :hugegrin:
Re: Glovebox light
I had trouble finding a bulb, mind you I always seem to forget I still need one, so if you do track one down let me know!
The glovebox light should only work when the ignition and the lights are on.
Re: Glovebox light
I was in Halfords today, and picked up a bulb that fits the light. It is 10watt but better than no light! Halfords number is 269.
I stand corrected, the light will work without the lights on but the ignition must be on.
christhemann
Re: Glovebox light
Ah interesting to know thanks!
Finally found the right number, but Halfords don't sell it.
Its 257 Festoon. Found some at www.consumabulbs.com.
Suppose with your bulb at least its brighter! Probably lights up the whole car.
:hugegrin:
dozzum
Re: Glovebox light
Post by dozzum »
That yellow/black wire also comes in handy for making my radio switch on and off with the ignition.
Just what i was looking for.
Re: Glovebox light
christhemann wrote:Ah interesting to know thanks!
Its 257 Festoon. Found some at http://www.consumabulbs.com.
:hugegrin:
£3.95 for a bulb :!: :!: :!:
My 10w is okay, and to be honest it only gets used by me, and I would not be driving and rooting around in the glovebox at the same time.
