Front anti roll bar stud
Tambarineman
Post by Tambarineman »
Has anyone replaced the studs that hold the anti role bar clamp?
One of mine snapped when removing the clamp :x
Sort of lucky it's not snapped flush :?
Any ideas and info on what the stud is made from and how it's attached would be appreciated
Cheers jack
1989 Scala injection sapphire blue
mr.brown
Re: Front anti roll bar stud
Post by mr.brown »
The stud is part of the wishbone mount - see pic below
Tambarineman
Nope the the studs that are permanently attached to the chassis
mr.brown
Post by mr.brown »
So you mean the studs that hold the wishbone clamp? I think Martin's answered that on your Facebook post
Tambarineman
Yes sorry that's what I meant and yes he's answered it but wasn't what I was wanting to hear.
Oh well More pain for me, wonder what else I can break
mr.brown
Post by mr.brown »
Hah, I know the feeling well. I've just ordered all new wishbones and bushes - what's the betting that I'll break something now!
You can sometimes stop things shearing off by cleaning the thread with a wire brush, spray on some plusgas penetration fluid (WD40 is rubbish) then loosen the nut a little then do it back up, loosen it a little more and tighten it back up loosen it a bit more then tighten it back up and so on... this stops the dirt and rust locking into the nut causing it to seize to the bolt. It sometimes work or if the bolt/stud is to far gone it will shear off what ever you do.
Tambarineman
I have also found that if you drop the rear axle off. Do not wreck the pivot bolt washers especially the cupped one cos they are obsolete and it took 7 weeks for heritage to get some to me. So if the bush isn't buggered leave it alone.
You mean this one?
Its in stock here for a genuine VW washer :-)
http://www.classic-vw.co.uk/mk1-golf-re ... 3106-p.asp
