High beam works when headlights are on and stalk is "clicked" back but not when "flashed". Does this suggest a dodgy stalk switch?
Jeffrey's
Hi beam flash
Radorocco
Hi beam flash
The Triumph Twins - 1973 GT6 and 1980 Dolomite 1850HL
The Karmann Krew - 1986 'Rocco GTX, 1995 Corrado 2.0
MGB roadster - the "Dark Side"
Re: Hi beam flash
not sure what you mean but usually with the headlights on if you pull the stalk towards you once so it clicks turns main beams on and if you pull it again till it clicks turns them off.
Re: Hi beam flash
They should flash without having to click them back, have a look at the stork contact as it's surprising how much dirt and fluff gets behind there so a clean may help.
Re: Hi beam flash
The stork may be your problem, you should have a stalk fitted... sorry, couldn't resist! :)
1985 GTL 1.8
Re: Hi beam flash
A stork has always worked for me, I poke the bird out the window and get him to flash!marcus wrote:The stork may be your problem, you should have a stalk fitted... sorry, couldn't resist! :)
duggers
Re: Hi beam flash
Crud on the contact ring ,oh err missus titter ye not.
Actually check as mentioned previously that you don't just need to get the contact cleaner out.
Membership # 432
Membership # 432
