under bumper fog light
britishrocco
wondering, if all scirocco sold in UK came with those fog light fitted under the bumper, or if it was an option?
Re: under bumper fog light
All UK Cars had them except for the 82 GL - that had the fog lamps above the bumper in the same position as the driving lamps most models came with.
Even my 82 CL had them even with its single light set up.
http://www.driversfound.com/scirocco/history/uk/
EDIT - it looks like my CL was unusual in having them, brochure says not stanard, check later years for specific specs.
That is a quality resource!! Ive a couple of brochures, but think 92 and 88/89 so don't have my 91 scala spec. The 91 brochure scala doesn't have the fogs funnily enough, but any i've seen generally did. Think they look better with themGTXTRA wrote:All UK Cars had them except for the 82 GL - that had the fog lamps above the bumper in the same position as the driving lamps most models came with.
britishrocco
Redroadster
Hi, does any one know the model n/o of the Hella under bumper fog lamp or the cover number ,the lamps measure 190mmx70mm,nobody on the internet seems to make up there minds.redroadster
britishrocco
steve bain
The under bumper fog lights I have, measure 170mm x 85mm.
Numbers on the lens on one read - 8336 R19 in the middle, above the word Hella; 304-118081 on the bottom left (as you look from the front).
There is no part number on the outside of the black casing. When you take the lens and the reflector (they are glued together) out, there is a metal bracket inside with the word Hella and TN19 and TN8 stamped into it. The VW/Audi part number label inside has Hella, the numbers 533 941 701 and 1ND 003 690-54 and the bulb designation H3.
On another, the VW/Audi part label has Hella, the numbers 321 941 701E and 1ND 003 090-49, and the bulb designation Lampe H3.
