Gearbox linkage sloppy and woeful brakes
barefoot
Re: Gearbox linkage sloppy and woeful brakes
Post by barefoot »
Sorted - a humungous two spline adjustment and we are back in the game with a shift that is slicker than Gary Glitters hair.
Thanks for all your help and advise.
PeteGLi
Post by PeteGLi »
PeteGLi wrote:You should not need to move the gear lever base plate. You should have a gap of 15mm (I think) between the bottom of the gear lever and the guide plate underneath the car. It sounds like you are a spline out at the front end of the gear lever shaft.
Haynes is quite good on setting up the linkage.
:whistle: :whistle:
barefoot
Post by barefoot »
Thank you Miss!
