Dazfx's 1985 GT
Re: Dazfx's 1985 GT
Haven't updated this for a while. Basically just moved house so decorating is taking pioratity at present. But also waiting on panels from Germany. As soon as all parts/ panels have arrived work can begin. Kind of stuck in limbo at the moment.
Re: Dazfx's 1985 GT
Right, so while I'm waiting for panels to arrive from Germany I have been
Checking all lights, switches and electrical bits work.
I have noticed that the rear wiper is not working.
So when I push the wiper stalk forward I can hear a clicking coming from fuse box
which I assume is the relay.
So I had a look in fuse box and all fuses are ok. But I have noticed that there is no fuse in slot 5 for fuel pump.
Which has baffled me as the car runs fine. I need to try a fuse in this slot to see if this will fix rear wiper.
Has any one had a similar problem?
Just trying to get little bits done while I wait for parts to arrive.
mr.brown
Re: Dazfx's 1985 GT
Carburettor car = no electric fuel pump = no fuse
From memory it's fuse 12 for the rear wiper.
Is the rear window wiper relay present?
Re: Dazfx's 1985 GT
Mr Brown just checked relay present and fuse intact.
I'm guessing the problem is nearer the wiper itself.
Have just read that the wiring can fail where it goes into the tail gate.
Another job for the list.
MikeH
Re: Dazfx's 1985 GT
If you haven't taken the fuel filler neck off yet, there is another way. Jack the car up and take the rear wheel off at the driver's side. brush the muck out of the gap between filler neck and body. Get a bright light in the rear wheel arch and take the fuel filler cap off. Look down the filler neck and if you can see patches of light, it's holed. If not, you'll probably want to take it off to re-furb anyway, but if it's badly holed you'll need to look for a new one first.
1992 Scala ABF - SOLD
1989 Scala track toy. Dormant
1.6GL. 2 Owners, 60k. SOLD
Re: Dazfx's 1985 GT
Thanks for the input guys. Just in the process of removing the rear beam. Having some problems with rusty bolts which just round off. Replacing all break lines though so will just cut hoses so I can get the rear beam and drums in the workshop to work on.
Next job after that will be the filler neck so fingers crossed it's ok.
Re: Dazfx's 1985 GT
I went to look at this one before you bought it I guess! Was too much work for me so glad someone else will get it back on the road! The rear 1/4 is rusted on the body joint under the boot lid, that with the rear valance its going to be quite the project! I will keep and eye on your progress!
Re: Dazfx's 1985 GT
The whole back end is rusty mate.
Just waiting on some arches from german ebay then going to start welding and swearing.
I hopefully take some photos.
Re: Dazfx's 1985 GT
Quick update.
So rear arches arrived today so work can begin as soon as I get a free Saturday.
Also have taken filler neck off and cleaned it up, only three little holes to weld up then it will be sent to powder coaters. Other parts ready for coating are rear beam and brackets and rear drum back plates. These will be for sale soon if any one interested. Hope fully get my phone fixed this week and will take some pictures.
Re: Dazfx's 1985 GT
So filler neck off and damage not to bad.
Few pictures.
The worst of the damage
New bracket to be fabricated and welded on.
Here we go.
All ready to be powder coated.
Now just need a spare Saturday so I can fit these.
Hoping to have them on and all the welding to the back end done by end of April.
Few pictures.
Here we go.
Re: Dazfx's 1985 GT
Some shots of the damaged areas.
Part of the drivers side sill I have already cut out.
Drivers rear arch
That's all for now until after Easter.
Drivers rear arch
Re: Dazfx's 1985 GT parts for sale
due to a change in job i will have no storage as of the end of may.
please look here many parts for sale
viewtopic.php?f=5&t=18619
many thanks
Daz
many thanks
Daz
