Rear Wiper Motor
scalainj
Rear Wiper Motor
Post by scalainj »
Hello
Any one know a source for these?
Andy
91 Scala
05 Alfa 156 Ti
06 Alfa GT
Re: Rear Wiper Motor
Scrappy, ebay... or do you mean alternative cars to source them from?
If the latter, look it up in the link in my sig. This will give you a part number. Of you then search the part number it will tell you all vag cars it was used in
Blueshark
Post by Blueshark »
If it's just the motor you need, I think I have a few spare .
Joost
scalainj
Post by scalainj »
Nate wrote:Scrappy, ebay... or do you mean alternative cars to source them from?
Yes or someone who might have one
Done so, i'll se what that turns up
Blueshark wrote:If it's just the motor you need, I think I have a few spare .
Joost
It's the wiper motor unit in the casing - not sure entirely whats died but there is power back there so i think the motor has called it a day though apparently the mechanism could be blocked. I need to take it apart further to be specific. Cheers
91 Scala
05 Alfa 156 Ti
06 Alfa GT
i know you have said that you have checked the live feed but have you checkd the earth is ok too?
scalainj
Post by scalainj »
Thanks all for your responses
I have checked the wiring through and through. It's fine
The motor itself is still working in the case but the mechanism is jammed.
I'm after the later motor with the part number ending in C and with the 13mm wiper arm retaining bolt
Does anyone have one going spare. It's the last part i need to have the car 100% working
Andy
91 Scala
05 Alfa 156 Ti
06 Alfa GT
i have a spare motor with housing but i will have to check what the serial number is.
i can tell you its from an 88 gtx though.
