Ignition Amplifier
Tim_R
Re: Ignition Amplifier
Post by Tim_R »
Mine wouldn't splutter, it also wouldn't happen every day, it just would cut out and have to sit there for a minute or two sometimes more for it to thaw out. Worth mentioning that carb icing does start occurring at air temperatures above 0 degrees C. The air has a cooling effect on the carburettor venturi causing moisture to condense and freeze on the sides when it was a damp or foggy day the problem would be worse as there was more water in the air to condense and freeze.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
