water in fuse box, source?
jim91
Post by jim91 »
Water leaking into fusebox, any tips on posible sources? Cheers :-)
Blueshark
Re: water in fuse box, source?
Post by Blueshark »
Leaky front window, underside sealant dried out or missing after window change.
Joost
Missing grommets in the front bulkhead above the fusebox.
Blueshark
Post by Blueshark »
GTXTRA wrote:Missing grommets in the front bulkhead above the fusebox.
Is also a possbility but that water useally does not get in the fusebox butt will soggy up your footwel carpet.
Joost
rust in window aperture or in the plenum under the screen.
sit upsidedown in the passenger seat with a torch and have a look for any tell tale rusty marks showing where the water has run
jim91
Post by jim91 »
Cheers guys, mate has taken to his shed to sort, I'll pass on the info and keep you's posted.
