ianaudia4 wrote:A 1470mm clutch cable is for a 1.6 GTi! The 1.8 injection cars need a 1490mm cable.
Give Volkspares a call on 0208 683 7442, last time I spoke with them they had 29 clutch cables of the correct length.
Ian's right - the longer cable is correct for the 1.8L injection cars. I've replaced the cable on my 84 Storm, and both the cable I removed and the cable I installed were the same length as the 532721335J part. The routing is neither too tight nor too loose.
These numbers are all the longer cable (1487mm cable):
532 721 335J (VW)
FKC1236
GEMO 434930
GEMO 434370
All of the above seem to be very good quality, and pretty close to identical.
I've had luck finding these cables new on eBay - they come up periodically. Currently someone on there has two new OEM cables for sale, but he's asking a lot of money for them (
http://www.ebay.co.uk/itm/Clutch-cable- ... 1c3eb8eb31) so you may be better off with Volkspares as Ian suggests.
