as ever Ian the "Scirocco Sage" has prvided good advice the suspension is relatively new 20mm drop Weitecs on gas shocks (whoever took Sachs over ?) the front ones were Sachs so i tried to match them (probably a mistake as they squeak like hell).
i knew there would be some bushes just wasn't sure which.
The top two are the anti-roll bar bushes, they can be a bit of a pyjama to fit but whilst you are there!
The bottom one are uprated bushes for the rear axle, the standard ones are part number 161 501 537 (actually listed as bearings!).
If you are going for uprated bushes then these have good feedback, I have never had them though:
