1982 1.5 CL Auto
Re: 1982 1.5 CL Auto
Yes, the econometer should nag you to change gear with a yellow light pretty much all the time until you're in top. I'm not sure whether the light would work in an auto, though. The swingometer should still pretend to give you an idea of fuel economy though.
Indeed. Used to really get in my t*ts after a whilethe edmundator wrote:Yes, the econometer should nag you to change gear with a yellow light pretty much all the time until you're in top.
Jeff
The Triumph Twins - 1973 GT6 and 1980 Dolomite 1850HL
The Karmann Krew - 1986 'Rocco GTX, 1995 Corrado 2.0
MGB roadster - the "Dark Side"
The gear shift indicator works by a series of vacuum hoses, first things to check as very often overlooked!
I think VW were very forward thinking when they launched the concept back in the early '80's, some of our company cars (which are all less than a year old!) have then fitted!
- Reverend Frog
My econometer works OK, but i doubt it is really of much value beyond being quite a cool thing to have.ianaudia4 wrote:The gear shift indicator works by a series of vacuum hoses, first things to check as very often overlooked!
It tells me that i can go from 50 to 25 mpg just by pressing the throttle slightly
Plus my car has never in its life done 50 mpg. on my way home from London it probably managed 40-ish tops.
40 ish is a good MPG, there are plenty of modern cars that would struggle to achieve that!Reverend Frog wrote:My econometer works OK, but i doubt it is really of much value beyond being quite a cool thing to have.ianaudia4 wrote:The gear shift indicator works by a series of vacuum hoses, first things to check as very often overlooked!
- The Milkman
- The Milkman
- The Milkman
- The Milkman
Passenger side not quite as clean, looks like crap has sat behind the mudflap and rotted through fro the inside out
- The Milkman
- The Milkman
Apart from that it looks pretty clean this side as well. Although for some reason it all looks to be body colour this side, where as there looked to be some sort of rust proofing the other side.
- The Milkman
All the screws for the mudflaps and inner liners came out fine apart from this bugger, bit of violence soon got the liner out.
- The Milkman
Had a look at the fuel filler neck, doesn't look too bad to me, one small section that I might replace with a bit of flexi. Inner arch looks pretty clean.
- The Milkman
The white bit is a previous repair that someone has done, looked like it had rusted right through. I'll get a proper repair done at some point.
- The Milkman
