Rear Bushes
Transporter2
Rear Bushes
Post by Transporter2 »
Hi, currently refurbing the rear end of my scala, new tank, fuel pipes, pumps, shocks, brakes everything shot blasted and repainted will be replacing all rubber bushes but it seems difficult to get standard rubber rear beam bushes anywhere, it seems that you can only get poly, if this is the case which are the softest, as I don't want to end up with a boneshaker!!. Have tried gsf, heritage, crazy quiffs, any ideas folks.
Re: Rear Bushes
Try searching for Golf MK1 rear bushes, they are the same. You could try VW themselves!
The part number is 161 501 537.
Re: Rear Bushes
I have not tried them but Powerflex get good reviews:
https://www.google.co.uk/url?q=http://w ... vvMwd1l4rg
Re: Rear Bushes
VW Heritage have them listed in their catalogue at part number 171 501 537.
They are £13.51 each.
Transporter2
Re: Rear Bushes
Thanks, vw don't have them any more, I was considering powerflex as they seem to be the most expensive and therefore probably the best, but would prefer rubber, i will check out heritage again, thanks for your advice.
Tim_R
Re: Rear Bushes
Post by Tim_R »
I'm sure someone on here was rebuilding a beam recently and found some new rubber bushes. I can't remember who or where though, sorry.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Re: Rear Bushes
Yes, they were listed on fleabay. Think it was listed as mk1 golf, but I can't find it now
Transporter2
Re: Rear Bushes
Thanks for input folks, think I will go for powerflex, as the only ones I can find are from cyprus and I am unsure of there quaitly. Let's see if pay more = get more, will post results in month or so when all back together. Cheers.
Re: Rear Bushes
The ones that were on there were gen vw
