8v cam
essextom
8v cam
Post by essextom »
Couple of questions-
Is the cam in an 8v carb ex engine the same as that in a golf gti 8v? If not how can u tell between the 2?
bengould
Re: 8v cam
Post by bengould »
If I remember rightly the gti cam fits the ex engine but the cam duration is different. It is what a lot of people use as a mild upgrade rather than going for a full on high lift performance cam.
Ben.
Re: 8v cam
bengould wrote:If I remember rightly the gti cam fits the ex engine but the cam duration is different. It is what a lot of people use as a mild upgrade rather than going for a full on high lift performance cam.
Ben.
correct.
essextom
Re: 8v cam
Post by essextom »
Cool, cheers for the help. Proper performance cam it is then.
