256 upgrade.. help with braided lines please!
treefingers
Post by treefingers »
So the plan is 256 vauxhall calipers up front and standard drums rear.. I want to use braided lines but they seem to come in full sets of 4 and the Vauxhall brakes use banjo connectors on the front so I can't use a full VW set. If anyone knows if a full Vauxhall set will work on my rocco that would be helpful.. the Vauxhall set have banjos on the front but normal connectors on the rear which is why I was hoping!
Here's the Vauxhall set.. http://www.ebay.co.uk/itm/MK2-ASTRA-GTE ... 23348ab136
Re: 256 upgrade.. help with braided lines please!
You just need to know the length of the vx rears to compare to your current ones. Will be the same thread on both.
treefingers
cool that's what i needed to know :)
