1992 GT2 Project
Re: 1992 GT2 Project
Haha ! Cheers guys! And its a Volvo 360 side exit on mini superlites really nice, its my friends so looks age when we go around together!
Awesome build and sooo good when it comes together for its first outing! Top work
insanecreations.net
insanecreations.net
Anther day another problem, well that what it feels like sometimes! The other night the fan belt started to squeak, a lot, so last night I loosened the adjuster nut to tighten the belt, then the whole alternator fell off! Somehow there was no bolt holding the bottom on to swivel on! Then I changed the oil, that wasn't so bad, put it on Ramps, let it idle then turned it off, out with the sump plug, off with the filter (very tight!) then put new filter on, was just about to put the sump plug back in was looking around underneath giving a visual check, and turns out, all the holds on the driveshaft were out 5 threads all loose!!!! So tightened them up, sump plug in, and I think we are all good for now, see what happens tommorrow! Just lucky I noticed it now rather than on my way to England, a little worried there could be something else though!
Charlie
Charlie
Bottom alternator bolt are available from the dealer, I know I've lost 2 in the past, the current one is held in with locktight!!!!!!
Luckily we have stainless ones for sale in our shop so managed to get it fixed, thanks though! will keep that in mindeefy wrote:Bottom alternator bolt are available from the dealer, I know I've lost 2 in the past, the current one is held in with locktight!!!!!!
Hi Charlie, Cars looking good! I had the same problem with an Alt bolt original allen bolt fell out on the way to work, managed to get a replacement but wasn't a great fit, not surprised it fell out again.Rascal wrote:Anther day another problem, well that what it feels like sometimes! The other night the fan belt started to squeak, a lot, so last night I loosened the adjuster nut to tighten the belt, then the whole alternator fell off! Somehow there was no bolt holding the bottom on to swivel on! Then I changed the oil, that wasn't so bad, put it on Ramps, let it idle then turned it off, out with the sump plug, off with the filter (very tight!) then put new filter on, was just about to put the sump plug back in was looking around underneath giving a visual check, and turns out, all the holds on the driveshaft were out 5 threads all loose!!!! So tightened them up, sump plug in, and I think we are all good for now, see what happens tommorrow! Just lucky I noticed it now rather than on my way to England, a little worried there could be something else though!
Charlie
As for driveshafts, I always forget something
Cheers Stuart, still plenty to do! just getting the time to get it done! yeah this ones stayed in so far!StuartGT2 wrote:
As for driveshafts, I always forget somethingI must have made it to Volksfling and back last year with them abit loose aswell, I'd recommend putting them back with Loctite, I'm sure I tightened them up but there a shit idea, never get a bit and socket that fits well enough to know there all tight.
so does everyone!! haha! well its done plenty happy miles so far with me! think it miht need a new fuel tank but the MOT due next week so going to see how that goes! will keep this thread updated!
