Hey folks,
as above i am looking to swap the bottom end of my DX engine,
I happen to have a 2.0L mk4 Passat (engine code - 2E)
my DX isnt standard though, i have already swapped in a TSR pack A head, Quattro throttle body, 16v WUR and a couple of other small bits and pieces.
my question is this, how easy is it to actually swap the 2E bottom end onto the Rocco, I know I need an adaptor for the distributor, but what else would I need?
also, which crank would make it a 2.1L? I've been told a diesel crank would make it a 2.1, but I don't know which one?
How many horse would it be putting out after all this too?
Thanks for reading (I know its been a bit long)
mk2 Scirocco DX bottom end swap
mr.brown
Re: mk2 Scirocco DX bottom end swap
The main thing to be aware of is that the 2E is a tall block engine - the block is some 15mm taller than your DX block. This can cause issues with bonnet clearance and also the exhaust manifold. Aside from the dizzy ring you'll need a breather block off plate. Quite a good guide here (although mk2 Golf based)
http://www.clubgti.com/showthread.php?9 ... sion-guide
ahh poop!!!!!!!!!!! i thought the 2E was a short block! damn!!!
hmm...... might need a rethink about which block I use!
Tim_R
Seem to remember the 3a is a short block 2L but not easy to find these days.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Mk2 Golf Gti 8v
I had a 2e on digipants in my mk2. No clearance issues, apart from not being able to find a 4 branch that would clear the rack.
- sciroccof529bax
Yh a few years ago now my brother built me 1 we used the dizzy ring converter had to put the cog off the 2e dizzy to ... Had Kent cam and verier pulleys two was a fast car after but we done total rebuild on the 2e wiv race bareings new rings re homled etc
