Mk1 inner front wings
I need to repair the inner front wing on both sides just the first 150mm around head lamp any idea on what may fit with a bit of alteration mk1 golf , polo .
Re: Mk1 inner front wings
I was a cheap stake and used a flat peice of metal and bent it a bit it fit but my hole was just above the indicator and once everything else was fitted you can see it any way!
Mk1 Golf inner wings should fit but I'm not 100% sure.
Mk1 golf is similar, depending how much of it has gone. Available for much cheapness too
