2.0l bottom end.
steviet_1988
2.0l bottom end.
Post by steviet_1988 »
Hey guys.
After eventually removing the old engine from my gtx I was going to go down the 16v route but I have been
Told to put a mk3 golf 2.0l 8v gti bottom end and use the dx head?
I have found a mk3 gti engine for cheap.
I was wondering if anyone else has done this before?
Stephen
86 monza blue gtx, currently in mid restoration.
Re: 2.0l bottom end.
Risocco
Post by Risocco »
Yup, mine is running one. Check my thread. :good:
steviet_1988
I just read through your build thread. Brilliant car!
What did you do with the dizzy? Im lead tho believe that the 2.0l dizzy doesn't work with the 1.8l head and vice versa.
Stephen
roccodave
Post by roccodave »
you need to fit a spacer ring to the 1.8 dizzy then fit the 2.0 drive cog to the 1.8 dizzy
Risocco
Post by Risocco »
roccodave wrote:you need to fit a spacer ring to the 1.8 dizzy then fit the 2.0 drive cog to the 1.8 dizzy
Yup, what he said.
You need this book in your life, will answer every question you have about the 2l swap. :good:
steviet_1988
Thanks. Where would you get one of these spacers?
Also what head gasket set, clutch and timing belt kit would I use?
Is the 2.0l bottom end and the 1.8l head better than the standard 1.8l engine?
Cheers, stephen
roccodave
Post by roccodave »
im not shure if you can buy them off the shelf anymore i had my spacer made by a friend any engineering place should be able to sort you out
use your standard flywheel and clutch
you will need a 2.0 cambelt as the block is about 17mm taller
i used a mk3 metal type headgasket but you can use the 1.8 as all the oilways ect still line up
it does make quite a noticable difference over the 1.8 i never put mine on a rolling road to see how much i had gained though
TSR used to do the conversion kit:
http://www.tsr-performancestore.com/tsr ... t-80-p.asp
Still might have them
steviet_1988
Thanks guys.
Would I use the dx camshaft or the mk3 gti one?
Thanks again
Stephen
Gilb666
Post by Gilb666 »
Seem to remember reading somewhere that the mk3 GTI cam isn't as good as the DX
