The Rocco Grotto
shavhead
Re: The Rocco Grotto
Post by shavhead »
Excellent!
Well done you pair! You finally got there.
:good:
Bet you are excited...
Ant more recent pics ant?
filmidget
Post by filmidget »
I took some yesterday that I need to email to Ant to 'publish' nicely.
The Autoad
Post by The Autoad »
Must be time for an update then.
Few pics of some recent jobs:
And Mr.Fleetwood did indeed pick up his Mk1, although i'll leave it to him to share at some point :vcool:
The Autoad
New job in, a late 1970's Scirocco GLS. Some of the long time SR gang will recognise this one.
Needs a bit of work.
The Autoad
Started dismantling the car for a closer look and to start the repairs.
Then things started falling off.
So had to start chopping.
chop
I needed to get some solid metal back into the car. Although it looks ok in this pic the floor of the car was rusty, it had parted company with the (now missing in action) lower edge of the inner sill and was wafer thin in places under the sound damping mats. Horrendous old 'repairs' put the nail in the coffin.
Chop.
New floor half going in.
"chop" and "new floor half in" makes it sound like it took you 10 minutes :hehe: stirling work, looking forward to the next update. enjoy todays delivery :)
The Autoad
Delivery was truly welcome and well timed sir :good:
So now the floor was in and lined up perfectly with the smidgen of of inner sill that was left I had me a datum point. Hurrah! So now i could get to chopping away the rest of the forward portion of the inner sill and putting in a new piece. I have opted to build the inner sill in two sections, replicating the factory.
So now i needed a datum point at the rear, as I was presented with this: (new forward portion of the inner sill just visible in this pic)
Strengthener had to be removed and put to one side for repair repair later so I could get to the rusty inner sill.
I cut away the worst of the inner sill (alot). The part that would provide me with a datum point for the rear would be this one as it wraps around the rear wheel tub. It would also replace the rotten rear beam mounts. I heart OEM repair panels.
Chop. Drill umpteen spot wells. Chop.
Good job that I did choppy chop. Hidden behind the chassis leg.
Are you sure you want a Mk1? :hehe:
Cleaned and painted with weld-through primer and the grotty bit cut out out and replaced with fresh metal.
Boom! New chassis leg/rear beam mount in.
Rear datum point achieved, the new section lines up with the new floor to accept a new inner sill section and is spot on for dimensions as specified in the VW manual. Phew! :swoon:
GT Matt
Post by GT Matt »
You rust magician you - it just disappears like magic!! :focus:
GT Matt
1988 Mk2 GTX
Bill
Post by Bill »
Yet again i tip my hat :hi: a true legend :beers:
shavhead
Post by shavhead »
Top work mate
I am amazed at the speed you've motored through this so far. Absolutely excellent work.
I just need to think of a way to get the money to send my camper in your direction too. Anyone want to buy a kidney?
markh
Post by markh »
Awesome work Ant, just awesome ! :good:
The Autoad
Thanks guys :hi: coming from you legends it means alot
Bit of a catch up:
New rear portion of inner sill built.
Inner sill was painted in a high zinc primer, the strengthener reinstated
And new outer outer sill
Still have the bottom of the A pillar and portion of the rear wheel tub that meets the sills to rebuild, but want to get on with the structural welding of the car first, so on we go....choppy chop chop....
Got the drivers side done. Two yummy new floor pans.
Forward portion of inner sill constructed
And again, new leg/mount is required at the back
Remove the crap
Drill, drill drill
