Rubber bump strips
NEW section - if you're having a mare with Vagcat and need a quick answer stick your requests in here. Keep things simple and only reply if you know the correct answer.
Don't know German? look here
harty
Rubber bump strips
Post by harty »
Morning Guys.
I'm looking for the part number for the rubber bump strip set on a Mk2 (front to rear)
Cheers Neil.
Blueshark
Re: Rubber bump strips
Post by Blueshark »
With or without the bodykit?.
Joost
harty
Post by harty »
Car is a 1989 GT with the black body kit.
With the plain black strip down the length of the car at waist height 5 sections to a side.
Cheers Neil
vw heritage is your friend.
most parts via classic parts - i've just placed an order for a complete gtx and a gtl set of trims.
harty
Post by harty »
I was told yesterday by vw heritage that only 2 sections for the right hand side of the car were available.
Do you have the part number for the set you have on order and are they the plain black type.
Cheers Neil.
harty
Post by harty »
Still looking for this part number / numbers if anyone has them.
i'll get the numbers for you.
i've not received a full set - some doubles though - because of part number supercessions.
also - a couple of odd pieces appeared, slightly shorter pieces that i reckon suit the later non body kit GT AND and narrower strip that i've never seen on a uk market car.
harty
Post by harty »
That would be great.
Cheers Neil
harty
Post by harty »
Still require the part numbers chaps if you have them.
Here is a link to the VAGCAT page, all the part numbers are there....http://www.vagcat.com/epc/cat/vw/COR/1989/13/56/186149/
harty
Post by harty »
Nice one Ian.
Will get on to it now.
