DX TTS..
Dave Dorson
DX TTS..
Post by Dave Dorson »
So am I right in thinking the TTS is the brown sensor/switch in the coolant flange at the front of the engine/into the tophose?
If so, I think mine is kapput :(, it'd explain my "cold" misfire and starting issues too.
Can you still get these?, or are they another "hard to find" part?
Looking at how it works, I assume anything above 30*c should be 0 ohms, and infinite resistance when cold?
Tee3
Re: DX TTS..
Post by Tee3 »
Yep thats the one.
They are almost impossible to find new now. I found a spare in a box of stuff after spending weeks going through every single Bosch agent I could find.
VW number is 043906163A
Bosch number is 0 280 130 214
there was a VDO alternative (also no longer available) i can get the number if its any use.
As I understand it they only run the 5th inkector anyway so should only have an effect on running for the first few seconds.
Dave Dorson
Re: DX TTS..
Cheers :)
VW want a fortune for it.
I've tested, mines actually OK, so I think my WUR is at fault.
Deep, deep joy.
