Hi all,
Since i got my GT2 a lot of people have said 'are you going to slap a weber on it?'
apparently they give more economy aswell as a bit better performance, But which weber would i need?
Its a 1991 GT2 1.8 8V
Cheers in advance :)
Which weber?
- bengould
Re: Which weber?
Its the 32/34 dmtl. It won't make that much difference to economy or performance, its a little more responsive but not by a big amount. The main advantage is its a much simpler carb with much less to go wrong.
Ben.
Ben.
Re: Which weber?
theoretically, it should be worse as it is smaller than the standard. but any idiot can set up the weber to run passably, where as there is probably only 3 people alive who can properly set up the pierburg
Re: Which weber?
Right ok, Ill stick with the pierburg until i get some problems then, its not a daily driver so wont matter if it breaks on me ect ect haha
Re: Which weber?
All I can say is "If it isn't broke dont fix it!"
