Front anti roll bar on a 16v
- whiteshark
Even though it did not come with one, I thought I better fit one. With new four branch fitted it is hitting the exhaust manifold. Should of seen it coming. Any work arounds, suggestions? Or is there any custom one or one from another car that will fit?
Re: Front anti roll bar on a 16v
All injection Sciroccos came with front and rear anti-roll bars mate!
- whiteshark
Ian, i know that. When I bought the car it had no front anti roll bar fitted! The problem I'm having is with the 16v KR engine and my new four branch manifold the front anti roll bar no longer fits as it is hitting the manifold. Anybody else on here with a 16v and a front anti roll bar and four branch.
Tim_R
16v - check, 4 branch - check, front arb - check. What do I win?
The arb will have a slight V shaped bend it in to allow space for the exhaust. Is the exhaust just touching the arb or is it impossible to fit because it would have to go straight through the middle of the exhaust?
Which 16v and manifold do you have?
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Mk2 Golf Gti 8v
- whiteshark
would it be posible to turn the anti roll bar upside down to give you a bit more clearance?
- whiteshark
No still hitting. Any other adjustable roll bars fit?
gti69
I have the same problem on my mk2 with abf fitted. I have 'mounted' a rubber exhaust holder on the anti roll bar and secured it with cable ties. I knew it is not going to last... was ok for a couple of days and then it slide to a side. I think I will just secure the rubber mount/holder with some clamps on both sides. It will still hit it but will not make that much noise.
Tom
VW SCIROCCO GT2 '92 |ABF inside -LHD
VW SCIROCCO GTX '84 |ABF inside -RHD
VW SCIROCCO MK1 '78 | czech carb inside -LHD
PORSCHE 924 '81 LHD
PORSCHE 944 '85 RHD
JAGUAR XJ6
BMW E36 320 Coupe
PORSCHE 924 '81 LHD
PORSCHE 944 '85 RHD
JAGUAR XJ6
BMW E36 320 Coupe
- whiteshark
Bump, anybody any suggestions?
The dub power manifold I'm running on the black car has a depression in I am pretty sure to help clear the bar.
16v also had bigger bars by the way.
If you know a decent workshop who can modify the pipe. That'll be better than any home brew mods to the roll bar.
As it happens the k bar had to be cut, one of the rear pointing links, on my car to accommodate dub power kit.
mr.brown
Real men don't need front ARBs.
big nick
Sticky tyres, coil overs and a front chassis brace will see you right :)
do I really want a carb'd valver? answers on a postcard...
