It's defo from the lights, can see it drip down from the bolts, might remove again and silicone around the bolt holes.ianaudia4 wrote:Jim, ref the lights, I put the sealant along the top and sides of the lights, not on the bottom. Don't overtighten the nuts, they can snap, I did this on two of mine and had to replace the light!
Did you put seal over the old one or on top of it if you get what I mean (ie between the old seal and the light)???
