removing rubber bump strip
vwglasgow
Post by vwglasgow »
hi guys been looking at some lovely roccos on here was wanting to remove the rubber bump strip around the car as i love the clean look any tips on removing would be much appreciated cheers mark :hugegrin:
Re: removing rubber bump strip
Heat it up very slowly (I used a hair drier) and slowly pull. On a low heat it should come away fairly easily.
Once that's done use some diluted white spirit to remove the goo (you could use a toffee wheel but I wouldn't suggest it). After that just use a little tcut and polish and bob's your uncle
vwglasgow
Post by vwglasgow »
Cheers mr funk :hugegrin:
