fuel pump upgrade for cam swap?
rewd53
Post by rewd53 »
hi all i was wanting to fit a "hotter " cam to my 1.8gt i have a weber to go on but was hoping to do a cam upgrade at the same time.
Would i need to uprate the fuel pump if i ; a) fitted a mk2 golf gti PB engine cam?
b) fitted a kent / piper cam?
if so what set up should i use? or which parts and where from? i do have a mk2 gti in bits if i can salvage all i need from there
Many thanx
Drew (rewd53)
MK2 Scirocco 1.8GT - "The 'Roc"
"Sell my VW ????? I'd rather shove wasps up my @rse"
Re: fuel pump upgrade for cam swap?
Don't think you'll need it matey. Plenty of people have done it
rewd53
Post by rewd53 »
awesome thanks
