Weber/ petrol hose
Derbyboy
Weber/ petrol hose
Post by Derbyboy »
Fitted my weber today apart from petrol house to short what diameter hose do I need
Thanks Paul
Re: Weber/ petrol hose
The part number you need is N 9009960, which should be 5mm.
Derbyboy
Post by Derbyboy »
ianaudia4 wrote:The part number you need is N 9009960, which should be 5mm.
Tar very much
Paul
available off the roll from any decent motor factor for pennies.
