0.5" dishes so it tucks like the trail fitted picture.
1979 Scirocco GLS 1272cc
Winston
Re: 1979 Scirocco GLS
ET45 will make them tuck alot. the 5" barrels are needed for clearence on the inside of the arch and coilover.
The interior of your fenders is like this:Winston wrote:ET45 will make them tuck alot. the 5" barrels are needed for clearence on the inside of the arch and coilover.
It's from an amrican rocco, if see with more attention you notice that he cut all the metal inside.
This is what i'm planing to do, and maybe after some fender-rolling to see if i can get an extra mm's.
The stock fender:
Edit: Did you already saw that irish rocco that i was talking about?
Lovin the tuck look mate, it's going to be great
...........and it judging from that mad mock up pic of the whhel and wing, it looks like the 'low off' is gonna happen!
Ps, my wheels are 5".......
Winston
Im having second thoughts about 15's and 16's... You can't tuck much dish without tubbing the inner arches as the bottom of the turrets gets in the way. I would like to keep the engine bay looking original or I would tub.
I was tempted to go with 5's.. Hero!!
The low off is still on though
Winston
Few of the new parts.. Most of the others are already stashed away out of harms way ;)
New Dbilas inlet manifold. its much shorter than the old one which means longer ram pipes :wub:
Fitted to the carbs. ready for the engine bay mock up.then I will strip the carbs for a rebuild.
Early Aluminium sill covers imported from the states. Im very tempted to polish these up.
Megajolt ignition. this means I can bin the dizzy and hide all the gubbins
Last but not least the part ive been looking for an early front panel from a jolly nice chap from Germany.
Nice upgrades,
Keep Going!!
PS: Sorry for the silly question, but why do you need an early front panel, it's any difference to the late front panel??
I thought they were the same, similar.
Keep Going!!
Winston
Cheers man
Early panels have an extra inch of metal on the bottom (duck bill) Mine has crash damage and is rusty inside. So as I needed to replace it I heald out for an early panel. It makes the front end lower to the ground ;)
Winston wrote:Cheers man![]()
AHhh ok, many thanks for the info.
Look at the new upgrade for my project, barn find:
Scirocco TS from 75 ou 76!!
It is a part's donor for my other scirocco!!
Winston
WOW good find!!!! loads of goodies!!!
You no longer need the bumpers you got off me now.
Please update your build thread with more pictures.
Winston
After 2 years of searching Ive finally got not one but two motorsport cam covers (the other is in the post)
Sorg Motorsport by Winstang, on Flickr
and in other news.
unwanted metal by Winstang, on Flickr
[/quote]
and in other news.
[/quote]
Winston
I bought myself some trumpets with my Christmas money. Its the 3rd set I have bought. pretty happy with these now. O0
The other cover finally turned up
VW & SORG Motorsport Camcovers by Winstang, on Flickr
- G60MAT
That VW cover almost makes me want to change my engine plans!
Winston
The motorsport cam covers are the only reason to have a small block haha
I am a few updates behind. I have kinda had a change of plan....
Winston
Thought I had already posted this up. Pony express all the way from Germany.
I have split the Mad'ins down to refurb the centres. I baked the wheels at 200* in the oven for 10 minutes and with a tap of a rubber mallet they split nice and easy apart from one! I put it back in the oven for another 40minutes. rubber mallet, wood and hammer, jumping on the wood would not budge the centre.
The only thing I thought I could do was cake it in thinners over night, add abit more in the morning and a bit of fire for good measure
Fire!!!!!! by Winstang, on Flickr
Did the trick
Did the trick
