hey everyone
this should be a easy job but the horn has wiring got me stumped
I emailed mountney to ask what boss kit I need for my 1988 mk2 scirocco they said I need the MB070
found one on eBay ...the wiring has got me stumped
i've been told the boss earths itself once fitted ...red boss wire to horn put it all together but still no horn
the horn works great with the original wheel I'm stumped
have I got the correct boss kit ?
what am I getting wrong here
thanks all
I hope to make it to meets this year
also I a stumped again on how to load pictures up on here I keep getting file too large every time I attempt to upload a picture
fitting a mountney boss horn won't work
- GT_II
Re: fitting a mountney boss
The maximum picture size I think is 250 kilobytes, so before you attach, for most photos you have to resize the photo to a lower resolution. Even then, the pictures upload very slowly. My guess is the forum server only has limited storage capacity.orangehippie wrote: ↑Fri Jul 15, 2022 4:04 pm also I a stumped again on how to load pictures up on here I keep getting file too large every time I attempt to upload a picture
A lot of users upload their picture to a picture sharing site instead then provide a link to that in their forum post.
hi GT 2 I have sorted the pictures now just need help on fitting the mountney boss now
i think it has a large contact pad that makes a connection with the brass connector on the steering coloum
i would simply fit it and then try the horn and see if it works
i think it will
i think it will
Re: fitting a mountney boss horn won't work
thanks James all ok now ...the problem was the small brass tag on the steering column it looked like it was touching the boss but was not ;)
a quick bend upwards and its all sorted
glad to hear it
