As winter is fast approaching i thought id do some maintenance as i know the top mounts need doing so...
I received one new top mount (still awaiting the other) from VW heritage... the thing is you can hold the shell in one hand and with your finger through the bearings you can move the bearings up/ down, left/ right, almost seems like the bearing housing is not fitted correctly to the shell of the top mount...seeing as i have never done this job before, am i right in saying the bearings should not move atall, and be solid. Its a Brand new febi bilstein kit, and i was told these are usually good!
Top mounts advise
Re: Top mounts advise
is it the bearing your talking about or the spacer in the center of the top mount that clamps up when attached to the suspension?
if i remember correctly, i think there is a fair amount of play when no weight is on the mount especially when its not attached to the suspension.
you could be right to be honest, i will have to compare with the other top mount that im waiting for, but it looks as though the spacer is moving as well as the bearings inside
they do tighten up considerably when under load so might have to see what they are like when on the car.
