Hi guys,
As you can probably see i am new to the forum and to sciroccos as well.
going to look at buying one tomorrow and was just wondering what i should look out for?
I know the basics IE. arches, chassis rails, book pan, floor pans, but this are generals for all cars.
was just wondering is there any known problem spots with scirocco's?
Car: Vw SCIROCCO SCALA INJECTION 1992
Thanks in advanced
Jack
Mk2 Buying Advice wanted
Re: Mk2 Buying Advice wanted
Welcome mate,
Start with this guide (in two parts)..
http://sciroccoregisterforum.co.uk/faq/ ... guide-pt1/
Try and have a good feel/check round the wheel arches under the body kit for integrity. Very hard to determine actual condition so take your time going round the inner lip of each arch. of course it's going to be easier to change the front wings if the fronts are rotten.
Also Entire fuel system can rust from filler neck, tank, fuel lines all the way to Combustion, Does it start from cold and idle fine? How is the fuel pump under the car (I am not an injection expert, someone might add their views?)
Overall body condition? Rust at rear number plate lights? Bulkhead where the clutch cable comes through can quite literately give way.
Finally Sun roof? An after market pop up style to my mind is not desirable, as long as it doesn't leak I suppose.
get some pictures up via a Photobucket account or other.
- Site Admin
Great thanks for the advice, I'll read the guide and let you know the outcome tomorrow, and ill also get some images up when I get some.
- Site Admin
All seemed good :) even appears to have a new fuel tank on it, It also had fair amount of work done by the last owner with part history.
All in all im chuffed :) I did say to the seller about this place and by the sounds of it he is a member so if you are make yourself known :)
Saw that on eBay, really like that paint job. I'm about half hour away from you in Ashford if you need anything
Nice one mate, looks like it has been given some TLC, part of a batch of white ones I see.
Would be worth making sure the tank and filler neck have some protection some sort of under-seal stuff like dinitrol, Dynax UB or whatever.
Loads of info on here if you search in relevant section.
- Site Admin
Great thanks a lot mate ill defiantly keep that in mindMr Funk wrote:Saw that on eBay, really like that paint job. I'm about half hour away from you in Ashford if you need anything
Yeah i agree, its garaged at the moment as being 21 the insurance isn't being a very nice figure... :(MacColl wrote:Nice one mate, looks like it has been given some TLC, part of a batch of white ones I see.
