16v WUR
millsy20
16v WUR
Post by millsy20 »
Does the 16v WUR fit on 8v engines. If so are there any power gains from doing this.
Rich
1991 Red Scirocco GT2-Soon to be GT2 16v
2010 MK3 Scirocco GT TDi 140 for daily duties
markh
Re: 16v WUR
Post by markh »
They do fit, and are supposed to increase fueling when you give it the beans. But im not 100% sure where the vacuum pipe is meant to connect on an 8v motor.
The Autoad
Re: 16v WUR
Post by The Autoad »
Vac pipe goes to the throttle body
millsy20
Re: 16v WUR
Post by millsy20 »
ok cheers for the info ill look into fitting it at some point.
Rich
PeteGLi
Re: 16v WUR
Post by PeteGLi »
The Autoad wrote:Vac pipe goes to the throttle body
Does that mean you need a 'Y' piece to join into the vacuum tube from the distributor to the throttle body?
MikeH
Re: 16v WUR
Post by MikeH »
Or a T piece, but that's effectively what I've done on mine - yes.
1992 Scala ABF - SOLD
1989 Scala track toy. Dormant
1.6GL. 2 Owners, 60k. SOLD
