Info On a 1.8T (Golf Mk4 GTI) swap
Hello Guys and Girls.
Unfortunately, the engine in my '91 Scala 1.8i has just seized (suspected bottom end) and it could be time for a new engine. the engine had just been re-built (not by me) and was in the stage of running in as it went. If the damage is fairly severe (It most probably will be) it could mean either sourcing a replacement, or something new...
It's been at the back of my mind to engine swap it at some point anyway, so this might be time too. I'm not really one for "keeping it original", sorry.
My question is other than the obvious (Engine, loom, gearbox etc) what are the hidden bits ill need to complete the swap. In the research ive done, the 1.8t will bolt up to my current gearbox, and one side engine mount will also line up but the other will need modifying. just thought id reach out on here to any of you who have done it and can give some tips/tricks. Also any idea of budget/secret costs that can slip under the radar.
Everything off the old engine will be available once the swap/repair is in full swing. its the 1.8i, the injection system is a peach and has always run absolutely faultlessly, the head had just been rebuilt and shaved, if undamaged, it will be available too. Plus all the auxiliary parts (it had a brand new water pump/starter motor and other bits so will hand them on dead cheap to those in need)
Any help will be massively appreciated! Stay safe x
- Site Admin
Re: Info On a 1.8T (Golf Mk4 GTI) swap
Loads of people will be able to help you I’m sure (unfortuanlty I’m not one haha) but I know Thomas from Dreadnought customs has done one and is always happy to help, as well as a few other guys on the Facebook page.
Jack
South East
VW Scirocco Scala MK2 1.8 Inj
Jaguar F-Type
South East
Jaguar F-Type
- essextom
Hi, ive done a 1.8t swap.
Before you start work out how much budget you have and how much of the work you can do yourself. if your not mechanically or electrically competent the costs will go up.
Do you want anything more than 200bhp? if so pay the extra and buy a bam code 225bhp engine from a tt or cupra r, its a litttle more to buy but will save you a fair amount in the future, also the install is a bit easier.
gearbox- dont bother with your one, use the donor one, its geared for the engine and will take the power.
things youll need to get or sort-
engine-
mounts (youll need a mount kit, originals wont work
intercooler and pipe work
modified engine loom
de immobilised ecu
some pipework for radiator
slimline rad fan
depending on donor engine you'll need to fit the drive by wire accelerator pedal
exhaust system, minimum 2.5" and a downpipe, this is where the Bam K04 conversion is a lot easier due to steering rack clearence
gearbox-
gear linkages ( i fitted the donor car cables and shifter under the car)
mounts (will come with mount kit for engine)
you'll probably have the correct driveshafts but may need the gearbox input cups
brakes-
def need to upgrade to miniumum 256mm front but id suggest g6o 280mm set up with larger master cylinder and brake servo
thats about it, its not a terribly hard mod if you know your way around a spanner.
engine-
de immobilised ecu
slimline rad fan
gearbox-
brakes-
Jack92 wrote: Mon Apr 27, 2020 9:44 pm Loads of people will be able to help you I’m sure (unfortuanlty I’m not one haha) but I know Thomas from Dreadnought customs has done one and is always happy to help, as well as a few other guys on the Facebook page.
Perfect thank you very much fella!! couldn't have asked for a better response. Im not looking to go for crazy power, for the foreseeable future it will, unfortunately/fortunately be my daily and for the sake of the roads where I live the stock power was more than enough fun! Brakes wise (something im very conscious of, and willing to spend the extra to get as much stopping power as needed) would the callipers/discs come off the donor car too? or would that require the hubs changing?essextom wrote: Tue Apr 28, 2020 8:27 am Hi, ive done a 1.8t swap.
engine-
de immobilised ecu
slimline rad fan
gearbox-
brakes-
And am I right in saying that you need driveshafts from an early Golf cab to use the donor gearbox??
To keep it simple use a donor engine with regular gas pedal, not this electronic fancy pancy :D
1.8t AGU is the engine code for that.
I used it for the swap.
Mine is 224hp, used k03s turbo.
All the mounts for the engine and gearbox are off the shelf from Epytec.de
Intercooler from a Mercedes Sprinter works like a charm.
Radiator I used from a Skoda Fabia ( cant remember which one exactly) but all the pipes hooked just right :D and added two slim fans.
For air filter works really well Honda S2000 OEM filter :D
And from the donor use also the gearbox and shifter, 02A or 02J are quite easy to fit into the Rocco.
02A can be used with cable clutch (needs a thingy), 02J need converting to hydro.
Check all the shifter and cable bushings before install, easier to change before install :D
Then just find someone who can convert the wire looms and couple of weekends of garage funtime.
Rocco goes turbo
- essextom
you cant use the donor brakes, best off finding a 256 setup or g60 setup.
your drive shafts might be correct, depends on your cars age, not sure when change over from 90/100mm was
1991 fuel injection Scirocco should have 100mm drive shaft flanges.
Thanks very much for all this gents. Will keep this thread updated with what I do. waiting to hear on the condition of the block.
I've seen a couple people say "Modified engine loom" or talking about converting the wiring looms. Does anyone know what this involves? what exactly is needed from the golf to be put on the Scirocco and what isn't needed? I'm not too familiar with the engine. For example does the ABS need to be transferred over to the scirocco to stop any fault codes popping up etc?
Any info would be much appreciated
Hyde
Hyde
