I own a mk1 GLi 1980, and I got it MOTD yesterday. Was looking forward to driving it to work this morning but it wouldn't start.
I couldn't hear the fuel pump so checked fuse box and sure enough one of the white blocks that plugs into the rear of fuse box has burnt out, see pics.
I've been advised that this is a common problem and that there is a way around it, but seeing as though I'm as thick as two short planks I want to know can you still buy those white block connectors that connect the wiring to the fuse box? I can't seem to find any.
Thanks in advance
Mal.
