Mk1 scirocco fuel issue - common problem apparently
Moderator: Scirocco Register
malmac
Post by malmac » Sat Jul 06, 2019 8:21 pm
ImageHi,
I own a mk1 GLi 1980, and I got it MOTD yesterday. Was looking forward to driving it to work this morning but it wouldn't start.
I couldn't hear the fuel pump so checked fuse box and sure enough one of the white blocks that plugs into the rear of fuse box has burnt out, see pics.
I've been advised that this is a common problem and that there is a way around it, but seeing as though I'm as thick as two short planks I want to know can you still buy those white block connectors that connect the wiring to the fuse box? I can't seem to find any.
Thanks in advance
Mal.
malmac
Re: Mk1 scirocco fuel issue - common problem apparently
Post by malmac » Sat Jul 06, 2019 8:22 pm
Sorry having problems uploading image, will keep trying.
Post by mr.brown » Sun Jul 07, 2019 9:37 am
Post by mark1gls » Sun Jul 07, 2019 10:02 pm
No point just fitting a new plug or the same thing will happen again, you need to find out why it’s burning out.
What’s the fuel tank like inside and any blocked fuel lines or fuel filters, blocked fuel pump intake causing the fuel pump to work over time and draw to much current?
Water damage to the fuse box.
Poor earth connection....
chopperoli
Post by chopperoli » Mon Jul 08, 2019 10:19 am
Yep that was a safety recall, many didn't receive it though.
The fix was a relay relocation kit called 171 971 761 B (now hard to find) to bypass the white block/plug, but you can make your own, I'm sure you're not really as thick as 2 short planks, it's not too difficult and all the information is at your fingertips these days
The reason is, on the early fuse panel the fuel pump is fed from a small pin terminal, it can't handle the current and heats up as you've seen
chopperoli
Post by chopperoli » Mon Jul 08, 2019 10:23 am
malmac
Post by malmac » Mon Jul 08, 2019 7:42 pm
Thanks for all your replies, really helpful.
Think I'll replace block connector anyway as looks awful but yeah, you're right need to find the route cause.
That link was great, just need to hunt down an adapter of some sort.
Cheers everyone, I'll let you know how i get on.
