1.8 8v g/box fit a 1.6 8v?
Mk2_phil
Post by Mk2_phil »
Hi, sorry if this has been answered elsewhere, I couldn't find it if it did!
Been told I ideally need a new clutch and g/box. I've got a 1987 5-speed 1.6 8v carb scirocco.
However, eBay and forum searches can only show me a 1.8 8v 5-speed gearbox. Will the 1.8 8v fit? and will it ruin my ratios?
Any advice would be seriously appreciated!
Phil
Mk2_phil
Re: 1.8 8v g/box fit a 1.6 8v?
Post by Mk2_phil »
UPDATE.
My gearbox code is 4T, 90mm flange diam, 190mm clutch diam.
How strict are these requirements when looking at other gearboxes?
vr_powered
Post by vr_powered »
Flanges can be swapped over so not an issue if the replacement box had 100mm flanges, dont worry about the clutch as long as its an 8v box from a mk1 or 2 golf/jetta or scirocco the clutch will mate up just fine, have a google for vw gear ratios as there are a few charts online so you can see which gearboxes have similar ratios to yours..
Mk2_phil
Post by Mk2_phil »
Nice one! Just what I wanted to hear.
Many thanks.
