what else could my problem be...?
Posted: Mon Apr 11, 2011 11:48 am
by obrut429
HI All,
I recently bought Kevin's Storm project from Durham and have swapped in another engine. There are new fuel lines in place and fuel hoses.
Before I began doing anymore work on the car I wanted to check the spare engine I had was at least functional - however, when I cam to try to start the car I am getting no fuel out of the injectors. the fuel pump does run fine and pressurize the system - with fuel getting to the fifth injector (which doesn't seem to be firing - but thats another problem!). When I lift the sensor plate and the fuel pump on - still no fuel from the injectors. Spark is OK.
So - I'm thinking I may have either/all:
1) Constricted new fuel supply line... but seems unlikely
2) Insufficient fuel pressure to the injectors ...need to check supply with a fuel injector removed and fuel delivery quantity as per Haynes
3) Faulty fuel mixture unit
4) Stuck mixture unit plunger ..but it feels OK and has smooth travel
Before I removed the old engine - it did run albeit terribly - so fuel was being received into the combustion chambers then.
Anything else I may have missed?
IAn
(Oh and the waterpump leaks and I think the engine has a problem elsewhere too - but none of these issues should affect the above problem...!)
Re: what else could my problem be...?
Posted: Mon Apr 11, 2011 12:26 pm
by vr_powered
Warm up regulator? controls fuel pressure and has a gauze filter which can get clogged up with rubbish, in fact i would be inclined to remove each banjo bolt one at a time and check the gauze filters as there are a number in the system (in the fuel dizzy) which by now if never touched before have probably caught a fair bit of rubbish
Posted: Tue Apr 12, 2011 5:07 pm
by bensspares
Might be realy daft here but are you sure the flow and return lines are the correct way round....same with the feul filter
Either
all 4 injectors nfu,
no feul in tank,
blocked filter,
f.p.relay nfu
disregard the w.u.r as this only effect mixture.
Posted: Tue Apr 12, 2011 9:52 pm
by bald rob
hi ,i've got very similar problem mate!
i traced mine to low fuel pressure in the return line from the W.U.R,
this means that the bi-metallic strip and/or heater isn't working or at least
working well enough to give correct fuel pressure back through the metering head
to the 4 main injectors.
i got stuck with this problem for ages,but managed to have chat with a VW trained technician.
worked for me,hope it helps you to mate :good:
Posted: Wed Apr 13, 2011 1:15 pm
by obrut429
Thanks for the replies - at the moment I've backtracked the problem to the fuel pump and/or a blockage from the tank to the pump - as the pump delivers zero fuel to the mixture unit. Will remove the sender unit this evening for a nosey...
Posted: Wed Apr 13, 2011 1:32 pm
by bensspares
Sounds like youve found the issue, blocked filter or pick up, hows that filler neck !!!!
Posted: Wed Apr 13, 2011 1:50 pm
by obrut429
ermm.. technical term I think is....crap.
Posted: Wed Apr 13, 2011 1:52 pm
by bensspares
sounds like you have the answer. its normaly something simple that causes the most greif.
