Grinding noise
Austin
Grinding noise
Post by Austin »
Was sat in traffic yesterday and the car started to make grinding noises when idle. Someone has suggested this is the water pump on the way out. Is there any truth in this?
Four Sciroccos, four gone, but at least I know all parts from most current one went to good homes....
fonzooorooo
Re: Grinding noise
Post by fonzooorooo »
Could be. Listen to it through a stick. Sounds silly, but it works!
vr_powered
Re: Grinding noise
Post by vr_powered »
Water pump, alternator, loose lower cambelt cover could all give you a grinding noise at idle, as has been said your best popping the bonnet whilst idling and having a listen and see if you can find where its coming from
Re: Grinding noise
Does it change/disappear when you press the clutch in? I think if the thrust bearing is going it can make a noise in neutral that disappears when you depress the clutch pedal.
Re: Grinding noise
fonzooorooo wrote:Could be. Listen to it through a stick. Sounds silly, but it works!
long screwdriver. tip on the bit you want to listen to, handle against your ear. just watch out for moving bits ;)
