oil pump question
johnsm
oil pump question
Post by johnsm »
is the oil pump in the 1800 carb ex model the same as the 1800 inj dx model,the gears in the oil pump of my storm dx are chipped and i have low oil pressure ,i have a good oil pump out of a1800 carb ex ,a 1989 model and i was going to fit this into my storm,both pumps are identical except thr gears in the oil pump in the ex are longer by about 4 mm,will this make any difference,any help and advice will be appreciated.
Funky Diver
Re: oil pump question
Post by Funky Diver »
In short yes... you should be able to change the intermediate shaft gear wheel over, but they should be the same, presuming it's coming off a similar year car.
vr_powered
Post by vr_powered »
Storm may well be solid lifter i really cant remember 100%, post 1985 was hydraulic lifter and afaik the oil pumps where different depending on solid or hydraulic
vr_powered
vw parts catalogue shows one pump listed throughout so they are the same no difference between hydraulic or solid lifter, dx same as ex etc
