my gtx nitemare!
Posted: Tue Mar 15, 2011 11:16 pm
by bald rob
hi all,just bought 86' 'rocco gtx,nice car only 76k miles!...runs like a bag of poo though!when i got it,changed headgasket,cambelt/tensioner,coil,leads,plugs,dizzy cap n arm as car was stood 4 a while.but wot seemed like a misfire remained with 'hunting' at idle or stalling n difficult restart. found filler neck to be heavily corroded[surprise!],cleaned out tank n drained it blew fuel lines thru,replaced main fuel pump,cleaned gauze filter n checked function n condition of lift pump,replaced fuel filter metering head[due 2 rust contamination] and fuel injectors.after doin all this, she still wont idle properly,still 'hunts',there's evidence of air in injection system and an air leak somewhere which can be easily heard, as well as loadsa smoke from exhaust,n still difficult 2 restart. i dont have any hair left 2 pull out,so bangin my head v v hard on workshop wall
has anyone any ideas or experience of this? please help...
Re: my gtx nitemare!
Posted: Tue Mar 15, 2011 11:20 pm
by ianaudia4
Where are you based mate?
Posted: Tue Mar 15, 2011 11:30 pm
by Old Mac Rocco
Posted: Tue Mar 15, 2011 11:53 pm
by bald rob
thanks 4 ref's, will look at them now.been around vw scene 4 a while,but this is my 1st 'rocco.always had mk2 n mk3 golfs,got my own bodyshop/S.M.A.R.T repair business in cardiff but this prob realy doin my head in,thanks guys
Posted: Wed Mar 16, 2011 12:26 am
by Old Mac Rocco
Posted: Thu Mar 17, 2011 11:36 pm
by bald rob
hey mate,v grateful 2 u providing refs,thank u.went thru check lists suggested n discovered perished upper seal on no.4 injector and slight weep on inlet manifold gasket.so reckon maybe onto a winner?! does anyone know whether the aux air valve is still available any where please? got part numbers bosch 028140158,vw 026133453,intermotor 14761.so far everywhere i try says no longer available. many thanks-rob
Posted: Thu Mar 17, 2011 11:39 pm
by GTXTRA
paragraphs make things easier to read btw.
Posted: Fri Mar 18, 2011 12:37 am
by ianaudia4
Have you tried the dealers for the AAV? I was quoted £130 back in 2010 from them!
I have a spare one if you are interested, pm me if you are.
Posted: Sun Mar 20, 2011 11:09 am
by bald rob
yes, tried vw parts dept,apparently now obsolete,and none registering in stock,but thank you for suggestion. also tried gsf,euro car parts,and spoke to inter motor themselves.
yesterday i cleaned out the AAV by soaking in carb cleaner and will test it tommorow.
just want to get my 'rocco on the road now
Posted: Sun Mar 20, 2011 7:17 pm
by DT1
If you don't want second hand and you are struggling to find, how about this?
http://cgi.ebay.co.uk/Leerlaufsteller-A ... 5633ed7d51
The company is actually in the UK so you could give them a call.
I'm not endorsing them, just found the link.
Posted: Sun Mar 27, 2011 11:35 am
by bald rob
thanks very much for the reference,this week i've tested my AAV,it appears to be in working order eg;
>its clean of carbon
>when warmed,the bi-metal strip moves the plate to allow/not allow air flow as governed by temp control device
>correct voltage (12v)supplied at connector with ign on and cold
when i got the engine to run for long enough, i noticed it still 'hunts' ,and will not accelerate easily.
tht is also coupled with back firing into the inlet manifold,and the sound of a definite air leak!
think i'd be right in saying,this is probably most of the problem?
hope i'm gettin somewhere close now,really want to drive my 'rocco
regards rob
