Bits in oil...
wasted
Bits in oil...
Post by wasted »
Just topped up the oil, and on checking the level, found these on the dipstick:
http://i387.photobucket.com/albums/oo31 ... C_2618.jpg
They're hard plastic. No idea what they are.
Anything to be worried about? Anyone able to identify?
PeteGLi
Re: Bits in oil...
Post by PeteGLi »
Check the plastic guide tube.
wasted
Re: Bits in oil...
Post by wasted »
Checked it - and the handle on the dipstick itself. Both intact.
PeteGLi
Re: Bits in oil...
Post by PeteGLi »
No idea then.
As to whether it is anything to worry about - unexplained solid objects in the oil would make me question what has broken?
I would probably drain the oil and drop the sump to see what else may be lurking in there.
wasted
Re: Bits in oil...
Post by wasted »
I just can't think of anything plastic that would have disintegrated inside :/ At least it's plastic and not metal though! I'll drop the sump out soon...
Re: Bits in oil...
Have you ever changed the dipstick? The older type of dipstick with the metal handle have like a hard and soft plastic seal on it and no plastic guide, the newer ones have the plastic guide and a plastic handle. I have one of each type on my cars.
As Pete says though, drop the sump and have a look sooner rather than later.
wasted
Re: Bits in oil...
Post by wasted »
I have the newer type - I just remembered that I had to replace the guide when I got the car as the old one was wrapped with Gaffer tape having broken in the past. Could be bits of the old one still in the sump. Either way, the sump will be taken off soon I think!
scirsteve
Re: Bits in oil...
Post by scirsteve »
It does look rather similar to the dipstick guide to me,
must be the remnants of the old one as you've said.
mk2 gtx
Re: Bits in oil...
my 2E had a plastic baffle round the oil pickup in the sump that had degraded and gone brittle. could be similar?
MikeH
Re: Bits in oil...
Post by MikeH »
Given the colour, if they're hard plastic, then it's a bit of the old dipstick guide. Sump baffles are all black, as far as I've seen.
If it's softer rubber, it could be an oil seal, but I don't think any of the genuine VAG oil seals are red, except maybe some parts of the rocker cover seals?
1992 Scala ABF - SOLD
1989 Scala track toy. Dormant
1.6GL. 2 Owners, 60k. SOLD
Whitescala89
Re: Bits in oil...
Post by Whitescala89 »
I found a load of these in the bottom of the sump when i took it off a while ago was curious where they are from.
