Help!
Posted: Sun May 24, 2009 11:51 am
by batman
As the sun is out I thought i'd get a few jobs done on the Scirocco today. I've just replaced the air filter with a nice new k&n one, but after replacing the air cleaner cover and re-fastening the clips, I dropped the mounting nut into the engine bay - doh! It looked like it went in behind the alternator and I can't find it - it definitely isn't on the driveway either! Now I can't find a suitable nut to take it's place. Firstly, can someone tell me where to get a replacement, and secondly, is it safe to use in the mean time? Thanks
Re: Help!
Posted: Sun May 24, 2009 3:45 pm
by Boumsong
Got a jetwasher? If so, give the area where you think the nut has gone a little blast, should see it drop out to the floor then. Try and keep the water away from air intake and spark plugs etc etc though.
Re: Help!
Posted: Sun May 24, 2009 4:06 pm
by wiredsubzero
ive heard a good way is if you have a good hover get the hose and put a thin sock over the end and tie it on the extending pipe with a rubber band and hover around that area it should suck onto the sock .
i havent tryed this myself but ive been told its good
Re: Help!
Posted: Tue May 26, 2009 6:08 pm
by james butler
this has happened to me so many times usually it gets tapped at a bit further down behind w/pump housing.use a magnetic pen an reach round the back of alternator n in the area. wouldnt like to say if it would be ok to run it wivout knowin where its gone.
