Clutch problem...
Posted: Tue Feb 15, 2011 4:05 pm
by ash-lough
I am having trouble with my clutch. Basically the pedal is not returning to the top after being pressed. It stays about ¾ of the way down and moves freely within that range.
I can just manage to get it in gear, but it takes quite a lot of force and crunches badly. It seems as if it would be an issue with the pedal rather than the clutch itself however I am not familiar with clutches.
Any help is appreciated,
Ash
Re: Clutch problem...
Posted: Tue Feb 15, 2011 4:21 pm
by ianaudia4
Check to see if the bulkhead where the cable passes through has given up, if it has it will need a reinforcement plate which can be bought from GSF and modified slightly.
I would also get a new clutch cable as it may be damaged where it passes through the bulkhead.
Posted: Tue Feb 15, 2011 4:26 pm
by ash-lough
I had a quick look at the bulkhead and it didn't look as if anything was different. What would it look like if it has given up?
The guy at C&R said it would need welding in the near future because it was on the way out.
Would that cause this problem then?
Posted: Tue Feb 15, 2011 4:31 pm
by ianaudia4
So it has been checked by a specialist then. Does sound like the problem. You could disconnect the cable and pop the grommet out of the hole in the bulkhead and take a look.
Posted: Tue Feb 15, 2011 4:34 pm
by ash-lough
Yeah, that was last year sometime when he mentioned it may need some welding at some point. I shall do that and take a look when I get home.
Posted: Tue Feb 15, 2011 4:45 pm
by ianaudia4
Good luck mate.
Posted: Tue Feb 15, 2011 6:12 pm
by DT1
Please, do it before it goes completely :beg:, it's a lot simpler and cheaper to deal with.
Posted: Tue Feb 15, 2011 6:21 pm
by ash-lough
DT1 wrote:Please, do it before it goes completely :beg:, it's a lot simpler and cheaper to deal with.
I am not going to drive it now until its sorted, good job I love walking to work in the rain!!
Posted: Mon Feb 21, 2011 10:40 am
by ash-lough
Been very unmotivated for some reason, however I am fairly confident that it is the bulkhead issue. I am not sure what it is supposed to look like, but it is at a funny angle and looks to have been pulled through.
Thinking of maybe taking it to C&R in Notts and having it sorted there, would I be best off doing that or will any garage suffice?
Ash
Posted: Mon Feb 21, 2011 10:17 pm
just buy the stick on repair plate. would be worth drilling the ends of the cracks to stop them spreading too
Posted: Thu Feb 24, 2011 10:36 am
by ash-lough
Nate wrote:just buy the stick on repair plate. would be worth drilling the ends of the cracks to stop them spreading too
Yeah didn't know that existed but found a few posts on here the other day. Have you done it yourself? Is it a good repair? Don't want it happening again in the near future.
