I've spoke to GSF and they sell a 'bulk head repair kit' listed for a Mk1 Golf that apparently will fit a Scirocco(Mk2) and just needs to be welded in place. Is this the best solution?
Thanks in advance for your replies!
Yes I had it happen on my first Rocco, it is quite common.RoccoYaz wrote:Hi guys and gals! As title says, clutch cable has pulled through the bulk head where its gone rusty and unfortunately I can't drive the car anywhere now. Has anyone had this happen to them?
RoccoYaz wrote: If so, how have you fixed the problem?
I "bodged" mine up for a week or 2 as I needed it for work. I just made like a big "repair washer" and cut a slot in it just big enough for the clutch inner cable to go through, and mate up the outer against. No weld or owt, just wedged it in place until I got the job dome properly.RoccoYaz wrote:so I just need to get it to a garage somehow... I've ordered a rigid tow bar which I thought would come in handy at some time!
Many thanks
Thanks Jim, do you think I could do it myself even if it means the car can then be driven to a garage?jim91 wrote:The GSF ones are self adhesive so you don;t need to weld it and as the clutch pulls towards bulkhead it will keep it in place. From memory tho it needs a few bits whacked off to get it to fit. Would probably be a much better job tho. I got one for mine and was gonna do as a preventitive measure when doing clutch cable, only to find that it had already been very neatly done and welded in by the original owner, think he made the repair piece himself, very tidy job!
Was that Trevor ?RoccoYaz wrote: My local GSF manager ...
That's the bit I like.you might have to make slight alterations with a hammer for a perfect fit.
Yes mate, Trevor is a legend! Small world eh?PeteGLi wrote:Was that Trevor ?RoccoYaz wrote: My local GSF manager ...
