Rubber Seals?
Posted: Sat Jan 15, 2011 1:48 am
by mikey360
Hi all,
Anyone know of a good British website that sell door seals, tailgate seals etc??
Got a few leaks on mine that I need to get rid of
Sorry if its already been posted!
Cheers guys
Re: Rubber Seals?
Posted: Sat Jan 15, 2011 9:35 am
by fonzooorooo
Not strictly the answer to your question, but...
Are you sure it's door/tailgate seals that're your problem? As far as I'm aware, they only tend to leak if they're damaged.
More likely are glass seals, boot lock seal and rear lights (oooh, and membranes inside the doors... or the adjustment of the tailgate catch...) ... If this is the case, a tube of tigerseal'll solve your problems.
If it truely is the door seals, and if it is due to damage, you'll get some off a broken car on here.
There's also the sunroof to consider if your car has one.
Re: Rubber Seals?
Posted: Sat Jan 15, 2011 11:39 am
by ianaudia4
The sunroof seal and tailgate seal are still available from the dealer, never asked for door seals but maybe you could!
Re: Rubber Seals?
Posted: Sat Jan 15, 2011 2:32 pm
by mikey360
The tailgate seal is starting to perish, definitely leaking!
And your right its more the glass seals and boot lock seal, she's a bit leaky
Re: Rubber Seals?
Posted: Sat Jan 15, 2011 3:46 pm
by DannyH
if it's the tailgate it's more commonly the boot lock seal and or the little blue things that hold the boot badges on.
Re: Rubber Seals?
Posted: Sat Jan 15, 2011 3:52 pm
by ianaudia4
The tailgate seal is £60 ish from the dealer. The lock seal is now discontinued from the dealer but can be bought from classic parts.
